I have a 1994 honda civic dx hatchback i have the non vtec 1.5 in the car right now but i want to do a engine swap . I bought the zc single 1.6 vtec engine with the ecu and automatic trans. My questions is can i use my old wiring harness?
This is a direct bolt on swap. You have to change out the distributor and thats it. Also if the motor came with the dual carbs. You will need to put your intake on the zc also.
