I'm having a few problems with my sensors and or wiring in my motor car and It's really buggin me.
My current setup is this. '89 CRX DX w/ B16A swap and a PR3 ECU.
My check engine light is on and my ECU is giving me the following codes.
I recently replaced my Intake air temperature sensor, or so I think. It was the sensor that is on the intake manifold. But the ECU still says that its not working properly, so I think it could be wiring problems, here is a picture of the sensor location that I did replace http://www.pbase.com/13898487/image/36287242
"2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor"
Is the Oxygen Sensor "B" the sensor that is on the exhaust right beneath the driver? And how can i check to make sure its working properly, or not. It is plugged in. (at least on the exhaust pipe it self)
"10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor" ? http://www.pbase.com/13898487/image/36287242 ?
"14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor"
"23) Knock Sensor - Defective circuit or unplugged / Defective sensor"
Can someone try to run me through on checking these things my self, it would be a great help to me.
Thanks a lot,
Scott
Thanks a lot,
Scott
