Wont go in gear at high RPM
Discussion in 'General Tech and Maintenance' started by Disco, Mar 18, 2007.
  1. Disco
    Disco New Member
    Hey I need some help here i did a swap and the car ran great untill the clutch master cylinder went out. I replaced it and now the car wont go into gear at high RPM. It also lurches forward with the clutch to the floor and giving it gas.
  2. hosmer
    B R I D G E W A T E R
    bleed it
  3. Disco
    Disco New Member
    i bleed it really well
  4. BrutalB83
    Rochester Hills, MI
    And why is this in the "auto multi media" forum??
  5. hosmer
    pull the boot off the fork and have someone step on the clutch
    if the cylinder isn't moving the fork all the way out, either you still have air in the line or the (new) master cylinder is junk...chances are theres air in the line. We had to use an electric pump to bleed it correctly, a gravity one wouldn't do it
    if it is pushing it out, the clutch/bearing are no good
  6. totalburnout
    NJ
    You need to bench bleed the master cylinder as per the shop manual, did you bench bleed?
  7. Disco
    Disco New Member
    I didnt bench bleed it
  8. totalburnout
    NJ
    Well, thats what you need to do.
