WOOT WOOT WOOT
Discussion in 'General Tech and Maintenance' started by formby, Feb 19, 2006.
  1. formby
    formby learning in progress
    IT FUCING STARTED
    THE CRX IS ALIVE
    IT WAS A FUCKING FUSE!!!!!!!!
    last night i decided that if by today the rex did not start i was going to do the ek swap...i did not sleep that well, but i woke up at 12.30....
    any way i take the car off the stands, take it out of the garage and put on the battery, same relay i put n my other post, and a volt meter....i started in the cabin and i checked the fuse box one fuse i remember fixing was blown
    so i cheched my book and i had put the wrong fuse in it ....well i fixed it ....the pump turned on and the engine turned over on the first try...
    since fucking JULY...... OMFG....i am finishing a joint and i'm changing the oil and putting the rad back in.... [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    sounds like a cause for celebration. ill light one up for ya [​IMG]
  3. ripperbone
    ripperbone angry bear
    Oklahoma
    nice and here you have been trying to sell it and part it out for some time, bet you glad you didnt sell it
  4. formby
    kinda.......i think i might sell the rolling shell....and do the ek swap
    its throwing a code 4 Crank Position Sensor....i think its because when it was sitting i turned the crank to make sure it wasnt stuck.....
    do i just put it back in time? or do i have to remove the timing belt and reinstall it?
  5. ScrapinSi
    ScrapinSi Senior Member
    Wait... Your car was down for SEVEN months FOR A FUSE!?!?!?
  6. formby
    yup...and i stopped working on it until the points on my licence went away
    i just got back from a ride....the fuse blew twice....thank god i was by a walgreens...WTF could be blowing that fuse
  7. StealthMode
    StealthMode Kung Foolin'
    Thornton, CO
    A short somewhere would be my guess....hmm.
  8. pissedoffsol
  9. formby
    should i check for burned out lights....exposed wires???
    ive never had to do this before :ph34r: :ph34r: :ph34r:
  10. reckedracing
    reckedracing TTIWWOP VIP
    NY
    first tell us which fuse it is
    i would check for continuity between wires which should not be connected...
  11. formby
    its fuse #15 10A alternator solenoid valve
  12. reckedracing
    NY
    is the alternator cooked?
  13. formby
    i dunno???? do i remove the ground from the battery or something??? to check th alt
  14. reckedracing
    NY
    well, it would help to have a tester...
    lol
  15. formby
    i guess ill take it to auto zone after work
  16. TurboMirage
    they only pull codes from obd2 cars.
  17. reckedracing
    NY
    yea but they'll check the charging system on ALL cars, for FREE!! :p
  18. formby
    after so long of not driving it. i forgot how loud it is...
    so i bought this
    and this cheap silenced can...
    and i have an 18" resonator already on there....
    i'm going to use this for now until i finish the turbo kit...then it goes on the HB
    do you guys think that magnaflow will quiet it down??
    BTW... i'm going to run the muffler straight out of the back... i think that looks so sick on a rex
    I also wanted an odyssey batery...which one is the one i need....and are there any other brands i can look at????
  19. reckedracing
    NY
  20. TurboMirage
