wow wow wow 16:1 compession what the hell
Discussion in 'Engine Building' started by typereg101, May 23, 2008.
  1. typereg101
    typereg101 New Member
    compression tesed type r it said 9:1 on first cylinder second 15 third 16 4th 10 anyone have any ideas on why its that high
  2. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    Theres a small animal in your engine?
    I have never hear of compression being so high unless you have a lot of carbon buildup, race pistons, or something else crazy. Check wih another tester or double check your conversion.
  3. typereg101
    nope dude trust me their is no darn animal in my mototr dude it would have got squished
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    How did you measure it?
    Compression tester is NOT for figuring out compression ratio. The only way to find your compression ratio is to take the motor apart, cc everything, and work it out in a mathematical equation.
  5. typereg101
    i measured it with a 300$ craftsmen compression leak down/ratiotester....ummmm wat math bro...n umm the problem was their was too much oil in the cylinder from sitting...lol but it started for 10 sec thencut off...the fuel pump does not pump for 10 min on second key turn but it doesnt...so i fix that n its goin to the paint shop...let me know thanks
  6. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    well you do a compression check and measure the PSI of each cylinder at TDC... and that wont give you the compression ratio. he's right the compression ratio is different than the number you get when doing a compression check.
  7. 92civicb18b1
    92civicb18b1 The Trisexual
    No one cares that your tool was 300 bucks, you could have bought a 20 dollar compression tester and it would have told you the same thing.
    A compression tester does not calculate your compression ratio, it measure the amount of pressure in the cylinder.
    I'm not sure I understand what you're trying to say on the fuel pump issue.
  8. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
