imzjustplayin
I want to buy a '92-95 Civic CX or VX transmission.
I also need a complete Civic HX engine with intake manifold and all. D16Y5 engine, head+intake manifold, wiring harness, ECU, etc. would be good as well.
I plan on doing a Civic HX engine swap into my Civic LX '98 and so I want to get everything that I need for that swap.
I believe I need to have the Civic HX engine come from an HX that was originally equipped with a M/T.
I need the following:
Civic HX M/T Intake Manifold (I expect a throttle body to be on there)
Civic HX M/T EGR valve
Civic HX M/T Short Block (Head)
Civic HX M/T old/original O2 sensor (should be normally included with full engine)
Civic HX M/T ECU
I'm ok with either the short block or the long block but if I get the short block, I'd expect a little more than just the short block itself.
I live in California so having all the necessary emissions parts is important. If you don't have all the necessary emissions parts, let me know and maybe we can still work something out..
Civic HX M/T ECU
