Want to buy or trade for a complete D16Z6 manual swap. A/C compressor need not be included. If interested in a trade it will be for a built B-series GSR. Info on engine below. I want cash. If you have the swap and cash I will give you $1500 credit towards the trade of the B-series. Email is the best way to reach me and local would be a huge plus. I'm in Channahon which is near Joliet, IL. btalkie@gmail.com The swap: JDM B18C (GSR) $6,000 complete swap w/ clutch Portflow titanium valve spring retainers JDM Type R intake and exhaust valves Portflow dual valve springs Micro ported and polished intake Hondata intake manifold gasket Z10 5 quart oil pan w/ wet sump pick-up JDM Type R crankshaft Skunk 2 cam gears STR rear cam seal JDM P72 virgin ECU B&M command flo fuel pressure regulator B-series a/c mount JDM B18C (GSR) hydro transmission Quaife LSD 99-00 Civic Si 2nd and 3rd gears Integra LS 5th gear (for gas mileage) Spoon magnetic drain plug Exedy twin disc clutch Neuspeed short shifter HAsport poly trans mount and drivers top engine mount Lemme know.
honestly I have never had it dynoed after i built it. its on a stock tune. I'm thinking about dynoing it tomorrow but i'm not for sure.
