wut am i missing
Discussion in 'Civic and del Sol - EG and EK' started by rudedawg2469, Nov 2, 2007.
  1. rudedawg2469
    rudedawg2469 h22.....the 12 sec. high
    jus bought a 92' hatch and im wanting 2 do a h22a swap, i've been told that i need the motor,tranny,ecu,shift linkage.......wut else am i gonna need 2 make this swap happen, sure could use a little 411........:confused:
  2. dacheat
    dacheat ..is grounded.
    strongbadia
    sounds like you're going to need some help ;)
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    you will also need the shiffter and motor mounts,and new axles
  4. norcalgsr
    NorCal
    x2 on the help part.. you should get someone that's done it before to help you out because it's not completely straightforward drop it in & go kind of swap.
    You're also going to need a die grinder or saw to cut the floor under the shifter out to accommodate the H22 transmission's shifter cables unless you're going to use an H2B trans conversion kit.
  5. bad eg
    bad eg mini me
    ca
    need 2 upgrade suspension,brakes cause dat shit heavy and maybe fuel pump.......
  6. rainer1386
    rainer1386 New Member
    Specializing in JDM-USDM Engines & Parts...hmotorsonline.com just buy their full swap and get the 92-95 civic swap kit. The only thing you will need besides that are some good wrenches and a sledge hammer. This is not a DIY swap for someone who doesn't know anything about swapping. I would start with a b series if you dont know anything and if you knoew very little a non vtec motor would be ideal.
  7. brian11to1
    brian11to1 Senior Member
    You're missing an H and an A...
    What... not wut...
  8. norcalgsr
    NorCal
    It's not as heavy as all the misinformation on the internet would lead you to believe.. under 100 lbs difference.
