y80 trans synchros crunching
Discussion in 'HYBRID -> EG-EK / DC' started by The ej1, Nov 27, 2008.
  1. The ej1
    The ej1 New Member
    So. Cal 310
    Just curious as to how long this trans is going to last. And if its worth just getting a new trans rather than just repairing the synchros. I have a JDM B 16A in my 94 civic coupe with a y80 LS trans. 3rd gear grinds 3 out of 5 times i hit 3rd. So I usually just skip 3rd gear if I dont need it. But 4th gear is starting as well. And if im at high rpm's they definately make a grinding noise when i put it into gear. Is this going to just get worse? Thanks
  2. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    through my experience they have lasted a while even with the grinding. Getting some synthetic lucas oil treatment seems to help. Try that and make sure the transmission is properly filled with lube. Theres a fill hole just above or near the passenger axle that you must wrench a bolt out to fill. just fill it in there till it starts to pour back out.
    Buying a used transmission has the potential to get you in the same trouble and rebuilding it can be more expensive than new/refurbished.
