LS/VTecEF9
Member
Hey I'm getting ready to drop in my new motor set-up after blowing up my Turbo ZC motor. I'm using now a OBD1 Cable trans YS1 "LSD" trans and I want to know what all you YS1 users are using for axles I mena what kind of car did you get them for and did you have to modify them at all. Here's what I've heard and know: All Y1 , J1 , S1 , trannys all can just use 90'-93' integra axles. BUT YS1 tranny you have to use 90'-93' integra axles and remove the washer on the axles and remove the dust cover from the hub Since YS1 trannys use alittle bite longer intermediate shaft then the , Y , S , and J 1's. So I just want to know what you guys had to use and what you had to modify. Y1 , J1 , S1 , really don't count here cause I know what do to with those but YS1 is different.
