z6 engine
Discussion in 'Engine Building' started by 1994ex, Jul 18, 2005.
  1. 1994ex
    1994ex Member
    i heard that cams and pistons will but what are the best cam and piston combination out there? Will i have to do anything to my ecu because i changed those out? What is hondata, uberdata, and all that data shit? which is the best one and how much does it cost? thanx
  2. CiViC_SOHC
    CiViC_SOHC Senior Member
    hondata and uberdata are tuners mostly used for fuel ratio increases and decreases...(turbo apps) the difference between hondata and uberdata and crome are uberdata and crome are free and hondata is expensive...crome is the best I THINK others might differ.
  3. sohcslammer
    sohcslammer Senior Member
    Bay Area
    **shakes head in disbelief** :(
    Those are not "tuners". Tuners are the guys who put your car on the dyno and plug away at your engine manegment system trying to reach the correct "tune" for your car. Tuning you car consists of editing stock fuel maps and ignition curves to adjust for bolt ons, internals, or engine swaps. This is extremely important because detonation is the leading cause of engine failure in sport compacts. Detonation happens when you do not have enough fuel supply in the cylinder and it creates a lean condition. Engine management systems, or "EMS"s as they are comonly called, are by NO MEANS just for turbo apps. Any motor that has been modified from it's factory specs, be it a cold air intake, to a fully built engine can benefit from "tuning".
    As for the differences between the EMSs everyone has thier own opinion and you best bet is to :search:
  4. CiViC_SOHC
    I didn't mean tuners I meant managment units..sorry lol..but sohc has it...
  5. Pewble
    Pewble Senior Member
    whats a good upgrade for a d16z6? a bolt on turbo kit.... or taking it out of your car and using it as a chair.
  6. sohcslammer
    Bay Area
    :newbie:
