ZC cam sensor gasket/o-ring?
Discussion in 'HYBRID -> ED-EF / DA' started by Periculum, Nov 13, 2007.
  1. Periculum
    Periculum Senior Member
    Martinez, GA
    I have looked at many parts lists for the ZC and have not found the gasket or o-ring that is for the cam angle sensor right in front of the distributor. Do I just need to get a fitted part? (napa generic o-ring) like I had to for my distributor or is there a specific part that fits this?
    note:It is possible that I'm just not recognizing the name for this part on the lists. Thanks in advance.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    it is the same o-ring as the distributor:
    part no. - 30110-PA1-732 - o-ring (26.4mm x 3.1mm)
  3. Periculum
    Martinez, GA
    Thanks a million. I assumed it might be, but I didn't want to run the chance of getting the wrong one then having a siv instead of a gasket (like that would be much different than it is now....)
    I'm assuming that replacing it is virtually the same as the distributor o-ring?
  4. jlicrx
    Colorado Springs
    same thing
  5. ers124
    ers124 New Member
    what alternators will fit a zc dohc
    hey you all. i just bought a zc dohc .i need an alternator that will fit this engine. will a si sohc alternator fit this. also if you know of any high performance alternators. i just need to know which ones will work and if theres some better performance ones to look for. thank you
  6. jlicrx
    Colorado Springs
    yes, sohc alternators bolt right on
