ZC Clutch and Flywheel Questions
allmotord16rex
Well, I'm through with day one of the ZC swap and the engine is out after dealing with the "bitch pin" in the shift linkage. I have a clutchmasters clutch I was going to install on my ZC, but the pressure plate wouldnt lineup with the ZC flywheel. Is there any difference in the ZC flywheel and the D16A6 flywheel.
I didnt mean to post this twice, sorry Mods, I accidentally clicked the back button and i thought that it didnt post, so I hit the post button again and it posted it twice. Sorry! Can a mod please delete these two posts?
Don't worry about it. If it's locked already, it will just fall out and die on its own. No reason for a mod to spend time looking for it and deleting it. You can try deleting it yourself too.
the ZC flywheel is the same as 89 - 200mm clutch - the 90-91 has 212mm clutch - use the Si flywheel
