zc dohc into rex
Discussion in 'HYBRID -> ED-EF / DA' started by 88rex, May 25, 2005.
  1. 88rex
    88rex Member
    i was told the only change putting a zc dohc into an 88 crx hf is the distributor wiring what is the difference and how do i wire it up and is this the only problem?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    No, there's more. :search:
  3. 88rex
    88rex Member
    what more is there
  4. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    did you not understand Calesta's post? SEARCH!
  5. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    you can use your hf dizzy with some creative mounting and it will run fine
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    use the HF engine harness - at the distributor, the HF harness has a round 7-wire connector - the DOHC ZC distributor has a square 5-wire connector - remove the connector from the HF harness and install the connector from the ZC harness onto the HF harness (connector from DX or 88-89 Integra will also work) - match wire colors on the engine harness side of the connection with the wire colors on the ZC distributor connector - you will have 2 wires left over, a blue with yellow stripe and a blue with a green stripe - these wires are for the Cylinder Position Sensor which is on the end of the exhaust camshaft on the DOHC ZC - remove the green 2-wire connector from the ZC harness at the CPS and connect it to the 2 leftover wires, again matching color for color - you will have one connector on the HF harness which doesn't connect to anything - it was for the EGR valve, which the ZC doesn't have - everything else connects right up - you cannot use the HF or Si distributor on the DOHC ZC engine
  7. 88rex
    88rex Member
    thanks for the great info
