zc swap in 89 hf
benjamin
whats up everyone I just need some help finishing this swap. I got the zc motor in with the si tranny and axels.can I use the stock hf spindle hubs or does it have to be si and or could i use dx spindle??? thanks who ever responds!!!
You have to use the si/dx spindles. You could also press out the hubs from a 90-93 non ABS integra and use those. Or you could get 1990-91 Civic EX front spindles for an upgrade in brake size (the integras also offer an incease in brake size).
if you want to use Si axles, you need knuckles/hubs from Si, DX, LX or EX
if you don't want to swap hubs, you can just use the HF axles - i would recommend you swap hubs to get the larger axles, but you don't absolutely have to
