zc swap
Discussion in 'HYBRID -> ED-EF / DA' started by zephon96, Jun 16, 2005.
  1. zephon96
    zephon96 Junior Member
    Buffalo, NY
    can anyone tell me where the location of the air idle control screw is on a ZC swapped motor? its in my 87 teg. not sure whether its location is underneath or on the side. thanx. --Jim
  2. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    Sure can. If you lift up the throttle control from ontop of the intake (where the gas cable attaches to), you will see a tiny little screw. Underneath the plate its attached to there is a nut you have to loosen to make the screw move, adjust it where you need it and tighted the nut back down. Hope thats what you need.
  3. zephon96
    Buffalo, NY
    I belive that'll do. thank you kindly.
