im curious to find out if a sohc zc swap would require any mods (rewiring etc) in my 89 dx hatch? can i use my stock ecu and stock harness?
All plugs and everything should be the same. Unless your Dual Point. Then you'll have to do a DPFI to MPFI swap. With the swap you can use a PM6, PG7 or the best PM7.
