zc
Discussion in 'Engine Building' started by demonboy1300, Jul 22, 2007.
  1. demonboy1300
    demonboy1300 New Member
    Harrisburg,PA
    ZC confusion
    Yeah, is there anyone who had an adapter or a head cast for a DOHC Vtec ZC? i keep hearing about ppl that have done this?
    Every where, so i dont know if ppl are mistaking b18's for dohc zc's or what but i want to knwo the definate answer to this. has anyone ever made a zc doch vtec?
  2. pops76
    pops76 New Member
    newfane new york
    d16
    so i assume it is much better to just swap a b16 into my 89 teg than try to work w/the stock zc ?
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    there are no VTEC DOHC ZCs - the stock 89 Integra engine is not a ZC - it is a D16A1
  4. klyph
    klyph Dismember VIP
    North Pole, AK
    Cuz it's JDM, duh.
    Actually it's probably due to the fact that you can run the ZC off of your stock electronics without having to upgrade to a VTEC ecu for the mini-me.
    Also, and Jerry can correct me if I'm wrong (as he often does :)), but the ZC has a halfshaft that makes the axles equal length, whereas the minime would have the uneven length axles.
    I'm sure there are many other reasons, depending on the particular application/situation. There is no one engine that is perfect for everyone.
  5. pops76
    pops76 New Member
    newfane new york
    sorry i am a newbie so i want to bracket race my 89 teg should i pull the stock d16a and swap a b16 if so do i need a new wiring harness ? it would not have to pass any emissions since i am just gonna race it
  6. klyph
    klyph Dismember VIP
    North Pole, AK
    Don't threadjack. There is a button that reads "New Thread"
    Use it.
  7. eg6sir
  8. demonboy1300
    Harrisburg,PA
    hahaha but i would keep the ZC in ur hatch, and do a custom turbo setup. im runnin a zc turbo in my 88 si crx im almost done, but it moves pretty good now.
  9. 89crxzc
    89crxzc I provide inspiration!
    ohio
    haha pwnge of the noobz, zc's are great motors, and instead of not going the zc route look into gude performance for a head build, if i dont go b16 then thats what i will do with my zc, they are great motors and depending on what kind of raicing you will be doing vtec might be a bad idea, in MY OPINION, though vtec is addictive.
  10. pops76
    pops76 New Member
    newfane new york
    sorry for threadjackin once again i am a noobie thanks for the info i am thinkin about a turbo set up on my d16a1
  11. demonboy1300
    Harrisburg,PA
    x
    HAHAHAHA
