TWOLOUDnPROUD
LX-R coming soon
Here is my 89 Accord Si with a (JDM) Turbo B20a. I will post mod list soon.
Update 8/12/08
My B20a is not the 88-91 Prelude motor it came in JDM 84-87 Prelude and 85-89 Accord Si JDM.This my first toubo porject i am going to try to get it right the first time:rotflmao:The B20a has stock bottom end and head for now.
Mod List
1.LudeSpeed Manifold
2.Costom APR Head Bolts
3.Costom Web Cams
....................Intake.........Exhaust
valve lift........ .420......... .430
Duration:........230............237
Duration@050 : 200.........205
Lobe Center.... 110...........112
Intake opens -10 Before TDC Exhaust opens 34.5 Before BDC
Intake Closes 30 After After BDC EXhaust Closes -9.5 After TDC
4. T04e 50A/R 57 Trim and .63 A/R Turbine
5.OBD-1 converion Chipped (Crome)P06 Ecu and B18A/B distributor
6.Stage 3 6puck clutch and plate
7.Precision 580cc injectors
8.B16 intake ported to 68mm
9. 68mm Throttle body
10. Two F22 cam gears
11. 35mm 8psi waste gate Tial knock off
12. custom intercooler
13.Ggay 2.5 intercooler piping Universal Kit
14 Greddy knock off Type-RS Blow Off Valve
15. custom front crossmember and front motor mount
Update 8/12/08
Mod List
3.Costom Web Cams
