sevndaythry
So when we undertook this swap we had no idea what we were in for. Unfortunately we completely under quoted for the work, at $500 for labor. Total hours spent were around 60.
The car was a 99 EK hatch, the engine was an interesting combination: It was an obd I ecu with an OBD II dizzy, However the entire engine combo was OBD I. The Ecu was a 4 Plug, Unlike the US spec automatic systems the JDM GSR Autos utilize the TCM inside the ECU. Upon Looking for a pin out for that ecu, I obviously wasn't able to find one. So we had to Plug all the harnesses together to the ecu and Reverse engineer the wiring system.
After finishing the wiring problems we had to install the engine. To make it fit we used the Manual Transmission 99 SI T bracket modified to fit the automatic. Part of the passenger side frame had to be trimmed so the transmission could sit in its proper place and a motor mount bracket had to be made from scratch on top of the transmission.
One of the biggest problems that was encountered was for a cable coming out of the transmission. the company that we bought the swap from had already sold the motor from the car they pulled the setup from so they mated it with a manual engine. The cable from the transmission connected to the wheel on the throttle body cam. Since it was a manual engine/throttle body there was to place to recieve this cable so I (quite ignorantly) assumed this was for cruise controll (I know bad assumption). After 1 burnt transmission I had to make a custom wheel, becuase the orientation was different than an LS auto.
Finally the Whole ordeal was completed, and other the driver we haven't had any problems. LOL J/K (not really).
Before you start ragging, yes, I know its pointless. And I dont want to go into why the customer did the auto. I just thought I'd post that it has been done. here are pics and vids. Sorry for the poor spelling, grammar, etc. but I'm feeling lazy.
The Victim:
The Guts:
I unfortunately don't have any pics of the wiring process on this computer, but to give you an Idea of what it was like. draw on a piece of paper a box and a crude engine then let a 2 year old draw on the paper with the pen.
The Install:
The in?:
The Mount:
Its Still an AUTO =( :
The videos:
Let your comments fly.
The Victim:
The Guts:
The Install:
The in?:
The Mount:
The videos:
