When to shift
awptickes
unimpressed by you
VIP
A common question from many new folks is "When do I shift?"
There are a few answers that newbies get, and some are wrong, some are right. This is just another method to use.
First, you'll want to get the gear ratios. Plug the gear ratios into this site:
http://www.housemanautosport.com/ratio calculator.htm
attachment.php
Then you'll need the diameter of your drive tires. Every tire is different, and wears differently, so you'll need to use your judgement. I plug it into the miata.net tire calculator:
Tire size calculator
attachment.php
https://hondaswap.com/attachment.php?attachmentid=8567&stc=1&d=1220607044
Input the data you just collected, and submit it.
Now you'll have some numbers, use these to work by. Go to a strip and test them out. There's some experimentation, but it's pretty on-the-money.
Now, stop asking "When do I shift?".
IMO, this way is wrong as well. You don't come up with your shift points by looking at your speedometer...
You get your fucking car on the dyno, see where the power band is, then figure out the shift point that allows you to stay in your power band.
The only problem I see with your method Awptickles, would be with the gear calculator. The average noob says, "I have a B16, so lets see, modify the rev limit value from 8000 to 9000. Sweet that should make me faster".
Which is why I agree with knowing your powerband.
And it's not only about the shift on the increase of rpm, but where the motor is after the shift, at the begining of the next gear as well.
Good attempt.
the IDEAL shift point is a shift that leaves your horsepower peak, and lands you on your torque peak.
if your car redlines at 8000, but peak hp is at 7000, on paper it doesn't make sense to wind it out.
BUT
if shifting at 8k drops you to 4k, and at 7k drops you to 3.5k, odds are that you're more in your torque band at 4k.
So, you're making more power from 7-8k then you are torque, proportionally from 3.5-4k, thus it's usually logical (on honda motors) to rev it all the way out.
so, yes, gearing (and even tire size) play into where you land... but it needs to be x-referenced against your peak hp point and peak torque point, and then averaged, and then rationalized, and .... i don't know... too much math.
just wing it out :D
no, he probably can't. that's ass-dyno territory :D
hit the rev limiter count to 10 then shift
ok i took this advice..it seemed to work great! my car is 20 times faster shifting like that i dont know why i didn't do it sooner! Does that work for all gears? I tried it on launch as well!! Other than some awful wheel hop it took off like a rocket!
yes this works for all the gears
for launch just hold the clutch and gas pedal to the floor when it hits the rev limiter count to 10 and dump the clutch, this will get you your best possible launch (this is the trick the magazines use to get their test results)
if you find you are getting a lot of wheel spin when launching like this, you need to warm up the tires more... for a FWD car the best way to do this is to put it in reverse, cut the wheel all the way to the right or left, stomp on the throttle using the same rev limiter 10 count that you want to use for the launch, then dump the clutch and count 10 full revolutions of the car, when finished turn the wheel the other way and repeat the process... after this your tires will be properly warmed up and you should get a sweet launch
if you are still spinning a lot on the launch you may need a wider and softer tire
Good advice, E! I'm gunna try it. I just hope nobody else finds out about this, cuz then everyone will be doing it and I won't have the advantage anymore.
I disagree. Lots of tire spin means that you are doing it right
If someone wanted to know any of this information, why not just look at your speed as you shift?
