ROFL Gl man on hondaswap.. Go to honda tech.. They get that you can be a noob and say dum shit or ask it..They dont have as big of mouths as these kids..Gl guy with your swap and info..
Again depends on what you want out of this thing... I'm not sure how much boost a stock B18 can handle but most D's can handle 8 psi or so no problem, and on a B18 that would be fairly impressive power I'm sure...
PSI is irrelevant. 10 psi on one turbo is different from 10 psi on another. Set a power goal, piece together your build, and then pay the money to get it tuned by a reputable tuner using proven parts. If you want to see good numbers, you have to pay good money.
The search bar will be your friend. Use it, or you will get flamed to high heaven.
You could get a d series for cheaper then the ls and get a vitara set up and piece together a turbo kit. D series are very cheap to build and can hold decent hp with stock sleeve's and suprisingly have pretty good torque. In an ef a 300hp single cam would be very nice and reliable and it wouldn't be crazy expensive.
