Compressor Surge or BOV
  • Thread starter Thread starter TurboRex90
  • Replies Replies 20
  • Views Views 8K
TurboRex90
Golden EG
Ok so im sure anyone that hears a car go by with a turbo, you love the sound of the flutter "tu tu tu tu tu". Although those with any knowledge in the forced induction field are aware of a thing called compressor surge or "cavitation".
For those who do not know what compressor surge is:
Compressor Surge- A condition caused by compressed intake air caught between the compressor wheel and closed throttle plates. When you get off the throttle after a burst of acceleration, the plates close but the compressor wheel may still be sending compressed air into the system. If the compressed intake charge cannot flow through the throttle plates, it will flow back to the compressor, causing it to spin "backwards", which could result in bearing damage.
Some of us know that certain Blow Off Valves can imitate this imfamous sound, one known example ise the Differential Bypass Valve or DV for short, which usually come on VW 1.8T.
An example:
The question that i want to know, and many other turbo enthusiasts may want to know is,
Is it possible to modify a standard BOV to produce the infamous "flutter", without causing severe damage, if any to the turbo without using a DV?
Thanks!
No.
The flutter/sneeze/bwoosh/etc. is the compressor cavitating. It can destroy bearings in the turbo, and it tends to at higher boost levels. BOVs also make the compressor work harder, because it's essentially a leak in the system. They create a pressure imbalance, and the compressor wheel stops spinning a bit before the turbine wheel; a BOV stresses the turbine/compressor shaft.
Ask yourself why every factory-designed system recirculates....
Personally, I hate that sound. It sounds like fingernails on a chalk-board mixed with screaming babies.
No.
Some days i like the sound and some days i cringe at the noise. I never knew that the BOV put stress on the turbo, thanks for some new information ^_^.
Where exactly would i have to recirculate my BOV to if i decided to do so?
Run a line off the end of your BOV (the end that normally vents to the atmosphere) and run that back to the intake tube for your turbocharger (where the filter would be, NOT where it goes into the charge piping). You may have to get a fitting depending on what BOV you're running.
Exactly.
What you want the recirculating valve to do is equalize the pressure around the turbocharger's compressor. Many factory superchargers do the same thing just because it's so damned efficient.
Wow, I guess you do learn something new every day! :D
I kinda wondered about recirculation. This knowledge will be applied to my turbo project :D +rep!!!!!!!!!!!w00t!!
EDIT) erm- could you clarify about where the recirculation should enter the charge pipe pre-compressor? "where the filter would be"?> Thanks!
Bahaha.... but i like that noise. :(
But i guess since im converting my setup into a "sleeper" i may want to invest in this idea. :rolleyes:
Personally, I'm one for setups that try to hide the turbo whine too. :D Make them think all you've got is a ricer-fart-cannon. :D
Then, while cruzing on the highway, some jackass in a VW (or in amerika: a big lifted pickup) comes up, tries to pull on you, and all you have to do is flex your ankle. That's tons of fun.
how do you hide the whine??
Insulate exhaust pipes, exhaust manifold, Intake and intake plenums, charge piping, intake piping, and use a quality air filter. Also, if you use a really cheap fart-can-muffler it helps too.
Exactly.
Recirculated system FTW. Drove my car today, it will be getting recirculated. Love Synapse because they already have a fitting on the end that is suitable for a hose and clamp. :D
