can someone help (revlimiter problem)
  • Thread starter Thread starter jdmh22a
  • Replies Replies 35
  • Views Views 4K
jdmh22a
ive just swapped in a h22a into my civic with a p13 ecu . the thing is the revlimiter kicks in at about 6800 - 6900 , im thinking this isn't right because i have seen them rev to about 8000 stock . has anybody else come accross this ? or have any ideas .
thanks
nope never happend just plug a p72 or a p30 up and see where it redlines with those
yup, thats what i use on my h22a the only thing is the p30 will not work your butterflies but the p72 will i just took my butterflies out so it didnt matter
il be getting a skunk 2 inlet manifold in two weeks so that will be ok , the p30 and p72 are for smaller engines yeah ? they probably have diffrent fuel maps i expect . at least il see if it redlines higher
i put the p30 on mine because my p13 was for a auto tranny and i got sick of seeing the check light on, but it run fine with me
yup thats it, slap out the ecu and see if that helps it should be fine after that
i have a 98 civic hx and i just did a b16a swap from a 99 si and im having the same problem my rev limiter should rev to 8000 but mine hits at 6400?
its a bitch in it , im going to try what aahvtec sugested soon as i find an ecu . the car still goes like fuck
do NOT run a p30 or p72 on an h22 unless its been chipped and has a custom program on it.
Not only do h22's have different sized injectors than the b18 and b16, the fuel maps are very wrong for it.
If you are throwing a code, fix your code first. There is 0 use in diagnossing a rev limit problem while you have codes showing.
ELD is wiried into the distributor wiring harness and has nothing to do with automatics, if that was the implied reference.
trace it down and make sure its wired in correctly.
