This information is intended to help everyone running a b-series transmission. The charts below list the top speed in each gear factoring in final drive and tire diameter. Obviously, there are other tire/wheel sizes here that I haven't listed however the sizes listed give you an idea when considering the small changes in overall diameter between slightly bigger wheel/tire combinations.
The below speeds/rpm drop down points assume an engine with an 8000 rpm redline.
| 15" wheels: | 205-50-15 Tires | 195-50-15 Tires | ||
| 14" wheels: | 195-60-14 Tires | 185-60-14 Tires | ||
| 13" wheels: | 185-70-13 Tires | |||
| 23.1" Tire Diameter | 22.7" Tire Diameter | |||
| Gear | Shift landing RPM | Speed @ 8000 RPM (mph) | Speed @ 8000 RPM (mph) | |
94-01 GSR Transmission (S80) | 4.40 Final Drive) | |||
| 1st | N/A | 38.7 | 38 | |
| 2nd | 4706 | 65.8 | 64.6 | |
| 3rd | 5726 | 91.9 | 90.3 | |
| 4th | 6082 | 120.8 | 118.7 | |
| 5th | 6089 | 158.8 | 156 | |
| RPM in top gear at 70mph: | 3527 RPM | 3589 RPM | ||
92-93 GSR Transmission | (4.40 Final Drive) | |||
| 1st | N/A | 37.8 | 37.3 | |
| 2nd | 5092 | 59.4 | 58.6 | |
| 3rd | 5545 | 85.6 | 84.5 | |
| 4th | 6070 | 112.9 | 111.4 | |
| 5th | 6323 | 142.8 | 140.9 | |
| RPM in top gear at 70mph: | 3922 RPM | 3973 RPM | ||
94-01 LS Transmission | (4.266 final Drive) | |||
| 1st | N/A | 39.9 | 39.2 | |
| 2nd | 4706 | 67.8 | 66.7 | |
| 3rd | 5343 | 101.6 | 99.8 | |
| 4th | 6090 | 133.4 | 131.1 | |
| 5th | 5913 | 180.5 | 177.4 | |
| RPM in top gear at 70mph: | 3103 RPM | 3157 RPM | ||
B16A (92+), USDM ITR, CTR Transmission | (4.40 Final Drive) | |||
| 1st | N/A | 38.7 | 38.2 | |
| 2nd | 5214 | 59.4 | 58.6 | |
| 3rd | 5541 | 85.7 | 84.6 | |
| 4th | 6074 | 112.9 | 111.4 | |
| 5th | 5128 | 147.3 | 145.4 | |
| RPM in top gear at 70mph: | 3801 RPM | 3851 RPM | ||
90-93 LS Transmission | (4.266 Final Drive) | |||
| 1st | N/A | 39.9 | 39.4 | |
| 2nd | 4706 | 67.8 | 66.9 | |
| 3rd | 5343 | 101.6 | 100.2 | |
| 4th | 6090 | 133.4 | 131.7 | |
| 5th | 6145 | 173.7 | 171.4 | |
| RPM in top gear at 70mph: | 3224 RPM | 3267 RPM | ||
JDM S1, J1, Y1 Transmission | (4.40 Final Drive) | |||
| 1st | N/A | 38.4 | 37.9 | |
| 2nd | 5051 | 60.9 | 60.1 | |
| 3rd | 5520 | 88.2 | 87.1 | |
| 4th | 6232 | 113.3 | 111.8 | |
| 5th | 6571 | 137.9 | 136.1 | |
| RPM in top gear at 70mph: | 4061 RPM | 4114 RPM | ||
European Integra Type R Transmission (98+) | (4.785 Final Drive) | |||
| 5th | 6128 | 147.3 | 145.4 | |
JDM Integra Type R Transmission (98+) | (4.785 Final Drive) | |||
| 4th | 6082 | 111.1 | 109.8 | |
| 5th | 6089 | 146 | 144.2 | |
| RPM in top gear at 70mph: | 3836 RPM | 3885 RPM |
