brian11to1
At idle or just above between 600 and 1000 rpm's my car makes a funny noise, here is what I know it isnt, Power Steering Pump/belt and AC/belt, Cause I dont have them, so the only other two things it could be are 1. Water pump bearing going out, or 2. the Alternator bearings are going out. It's sort of a whinning noise, annoying if you will, how would I know if it were the alternator or water pump?
