Christian_D
I just started a swap on my 1997 Acura EL (basically a civic EX vtec). and I have a few questions about the wiring differences. I was told that the harness for the b16a2 (OBD2) would just plug and play into the existing harness for the computer and the dash. However after taking out the D16, I noticed that on the drivers side near the windshield wiper, my Acura has a single plug (grey with a 10 pin blue insert) whereas the B16 harness that I have has 3 plugs (one white 14 pin, one white 8 pin and one grey 2 pin). Now since I was told by everyone that everything should just plug in and be good, why did this happen and what should I do now?
Can I just use the stock d16y8 harness if I run a knock sensor? or is there a way to make everything plug in properly?
PLEASE HELP! My car is sitting not running right obvoiusly and I need to get it on the road ASAP!
Thanks
Thanks
