#226 |
Ride: 1991 CRX Si
Yep, KMS is shipping the motor out tomorrow!(Friday)
He said he's gonna give me a discount on the price, too. (I shipped it Sept. 6!) And I picked up some brake rotors today. EF EX rotors, but I didn't get the Legend Calipers because I couldn't remember which one I needed to buy. My ideas for my brakes up front are Legend calipers/pads, EF EX rotors, SS lines. Then in the rear I'll throw on some DA rotors and calipers, and SS lines. All to go along with my 1" DC MC. Can anybody refresh my memory as to which year/trim Legend calipers I need to buy? I'm thinking 1995 Legend Sedan, but am not sure. Thanks -ANdrew |
#227 |
Ride: 1991 CRX Si
Update 12/15:
I've got some tires to get mounted(I've had them for a while, but decided to go ahead and do them this week) 195/50/15 Yokohama AVS ES100's. ![]() ![]() ![]() And I picked up some 10.3" rotors to fit under the Legend calipers(will buy tomrrow) ![]() ![]() |
#228 |
Admin with a big stick
Ride: 2003 S2000
Sweet! If you can find a way to mount another set of calipers on there, you could have the first super numma one double front brake system with awesome endo power on a CRX!
![]() __________________
#230 |
Ride: 2003 S2000
That would be badass! I'll bet you could market a brake system like that for about $10,000. Someone would buy it.
#231 |
Ride: 1991 CRX Si
I think Mike needs to step away from 'the pipe'.
![]() Speaking of pipes, I picked up some goodies to play around and make a homemade catch can! Shopping list is as follows: (2) 1/2" x 1/2" hose barb $1.44 (10pk.) 7/16"-1"hose clamps $5.72 (6') 1/2 ID braided PVC tubing $4.92 3" x 5' S40 PVC piping $7.07 (2) 3" PVC CAPS $5.16 = about $25. I still need to get a drain valve. (like $8) Heres my plan: ![]() Any tips I should know about? I'm thinking of sticking some steel wool or something in there to trap the oil.... ? |
#232 |
Ride: 2003 S2000
That looks good to me. I wouldn't worry too much about the steel wool. I actually had my catch can draining back into the block- the lower fitting was low enough that the oil could go back into the drain plugs in the back.
#233 |
Ride: 1991 CRX Si
Huh. That would be a good idea, that way I wouldn't have to buy a valve to manually drain it.(actually wouldn't ever need to touch it at all..?)
I mean, I can make the bottom drain hose as long as I want, so maybe I should consider doing what you did. Could you elaborate a little bit on which plug I'll be needing to drain to? |
#234 |
Ride: 1991 CRX Si
Got one end of the fuel line done. I can't do the other side because the motor/manifold isnt in for me to measure...
![]() ![]() Oh, lol, I was looking through the first couple pages of this thread, and couldn't help but think what an idiot I was.... It's funny how you wish you were as smart then as you are now... ya know? I wouldof been done with this garbage a LONG time ago!! __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 12-18-2006 at 10:30 AM. |
#235 |
Hey, that's what this site is for. I did my first swap based on this site and it turned out great. You're build is looking really nice, keep it up. I'm sooo envious of the quality of your CRX's body.
No tech questions through PM please! B16 CRX....you will be missed
#236 |
Ride: 1991 CRX Si
#238 | |
Ride: 2003 S2000
The plug I'm talking about is the giant brass plug on the back of the block. I don't think I have a picture of it, but there are 2 plugs on the non-VTEC blocks. The GSR might only have 1- the other is where the black box sits I think... __________________
#239 |
Ride: 1991 CRX Si
Well, I'm in the process of buying that prelude nipple to replace the black box to go to the catch can. Oh, and remember, this a A6 block.
I guess I'll have to figure out a way to incorporate a filter on the top of the can somehow. won't be hard, just got to find a filter. |
#240 |
Dismember
Couldn't you rig a fitting into an OEM oil filter and use that as a catch can? It'd be supa cheap and stock, eh, sort of...
#241 |
Ride: 1991 CRX Si
I'm not so much worried about cost. I just wanna make my own thing and see how it turns out. In time, I'll just invest in a real one and cut the small guy out...
#242 | |
Ride: 2003 S2000
#244 |
You need 94-95 Legend GS Sedan Dual Piston Calipers... or any 90-95 Legend will work or NSX... LOL
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#246 |
94-95 GS Sedan had the dual piston calipers so they wont be the same as ITR as ITR's are only single pistons...
#247 |
Ride: 1991 CRX Si
well, w/e. thats the stamp on them, and i'll just make sure it's dual piston.
ITR< Legend GS dual piston!!! lol my crx is gonna either 1. stop like a mofo, or 2. lock up all the time... |
#248 |
Ride: 2003 S2000
Just plumb it in place of the stock breather box.
#250 |
Ride: 2003 S2000
The breather box has to be fed from the block through some kind of fitting, right? Use what's left after you remove the stock box.
| Engine swap: d15b7 to d16y7; transmission? | oakley2002@cox.net | HYBRID -> EG-EK / DC | 7 | 10-28-2009 07:19 PM |
| Best Engine Swap For 95 Integra Ls | Agt_Orange_GSR | HYBRID -> EG-EK / DC | 7 | 09-23-2008 04:16 PM |
| EE crx engine swap. | DAZ81 | HYBRID -> ED-EF / DA | 6 | 11-25-2003 10:21 AM |
| 81 Civic Engine Swap Help | fjcisco13 | HYBRID -> EG-EK / DC | 3 | 04-23-2003 06:16 PM |
