Ride: RX5.7 Civic LS and Teg Ls
ok i have been looking up headers for the past week and i have noticed there are more choices for the b18 then there is for the b16 now i know the b18 is taller then the b16 so i wanted to know is there a major difference with the actual hook up of the exhaust? meaning am i going to have to make special bends or move my cat around so on so forth if i get an integra header. or is it just going to be closer to the ground then the b16 header. the reson why i am asking is because in the next year or so i am building a b18 block to put my b16 head on and i don't want to buy another header later on in the game. so should i just get the b18 header and call it a day? or is it going to be more work getting a b18 header now?
also is there a big difference with the usdm header and the jdm itr header? __________________
Check Out My Car Club www.HighRevCustoms.com and join the forums this is what happens when you are bored out your mind!!:| [[-]] (()) ||\|| ||)) //-\\ (( || \\// || (( my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
get any b series header they all mix and match ( i bould recomend a b18 header)....i used a stock b16 Exh manifold on my lsv for a while then i bought a cheap Egay b18 header until i finish my turbo kit..... the size of the tubing is smaller on a usdm header.....
thanks man that is exactly what i needed to know i guess for the time being i am going to go with an ebay one because i am also parting together a turbo kit do you still have that header?
Admin with a big stick
Ride: 2003 S2000
The B18C header is taller than the B16A header. The B16A header will work on a B18A/B and a B20B/Z block, but most will hit the oil pan on the bottom of a B18C or a B16B because of the deeper pan (has to clear the girdle). To be safe, the taller B18C headers will work fine with all B series blocks. The hookup to the exhaust is the same- you won't have to modify to change between the two types of headers.
#5 | |
dosterschill __________________
democrats: democracy is an exercise in practicality, not idealism; we reserve that for the likes of communism
#6 | |
MB4 X2
'99 Acura 1.6EL Premium VSM 5M '98 Acura 1.6EL Sport VSM 4A |
#7 |
Brutal Moderator
Ride: 97 Integra LS Coupe
I'm glad your excited man, but next time check the dates on stuff before you post. This thread is over three years old...
#8 |
MB4 X2
Good eye, lol. All the same, I find that many of the things like that, it's easy to find the what, but much harder to track down the why.
#9 | |
Ride: 2003 S2000
