eBay Motors: RACE GSR HEAD CUSTOM INTAKE DUAL WEBBER READY INTEGRA (item 260278039620 end time Aug-28-08 20:37:19 PDT)
maybe I'm not understanding something....?
How is a single weber carb going to flow with a 4 cylinders and make high horse power?
but normally, when going to carbs...it's one venturied carb per cylinder...not 1/2 ventury per cylinder. There is just no air flow, unless your using a 60+ mm ventury carb. The largest weber is a 50mm, and the largest mikuni is around 50 also...
I know because I've had 40mm triples on my L28, and it flowed like shit...and thats 6 cylinders with 6 venturies. For my engine to flow right I needed a 45mm or bigger. For my little 1.5L honda, I'll need at least two dual 40mm mikuni or webers for it to run right, and it still doesn't flow as much as a GSR does thats a 1.8L. Tossing on the max single dual carb on a GSR just wont flow, and it will run like crap. Unless your boosting the crap out of it, but carbs can only handle 8-9 psi.
Please show me one built engine thats a 4 cylinder running with one duel carb and making high horsepower.
