do you have any idea of the wiring ill have to do if anyMake sure you get a 90-91 cluster because 88-89 will NOT fit in a 90-91 car and vise-versa.
Other than that it bolts in perfectly and everything works like stock.
and also everything that i see is for 88-91. nothing shows for just 90-91?Make sure you get a 90-91 cluster because 88-89 will NOT fit in a 90-91 car and vise-versa.
awesome thanks for all your help. one more question though. does it matter if the car is a 5spd or 4spd?Since you seem like a nice guy I did a eBay search for you.
This is all you need:
88 89 91 HONDA CRX CIVIC Si instrument gauge cluster - (eBay.ca item 250362319572 end time 30-Jan-09 17:45:17 EST)
No, does not matter.awesome thanks for all your help. one more question though. does it matter if the car is a 5spd or 4spd?
nice! just ordered it.(but i got one with a lower mileage odo). he heNo, does not matter.
Just wondering...
If you got gauges with kmh instead of mph could you take them apart and put your speedo into the gauges with the tach?
you mean take the kmh overlay out and replace it with the mph? yea its the same size and such just labeled diff...gotta be careful not to break the needle tho
Yeah you can do that, you have to take off a lot of crap to get there though.No i wanna pull the full mph gauge out of the cluster and switch them.
I was just wondering. Cause every cluster i find cheap is KM/h and i did it in my accords so i wanted to know if the kmh and mph would be the same size to swap em out.
I guess ill but the next cluster i see cheap and use my mph gauge.
Thanks and +rep if i can.
