how come? saw something like that?lol
yeah, but it might look and sound kinda funny.. really depends on the differences.
might sound even better then two identicals.
no how come it will sound better than twinshow come what?
why would it look funny?
i dunno, i just think it would.
same amp with same channels? or for example 4 ch amp with bridged 1/2 3/4You can, but it is going to be tricky to get it to sound right. If you run them off of two seperate amps, you need to be careful or you will experience cancellation. The best idea here is to run them off of the same amp, and make sure you stay right around RMS on the sub with the lowest RMS rating.
i didnt say it would.no how come it will sound better than twins
If the box has a piece of wood separating the two subs, ie two separate chambers, then it doesn't matter. If it's one big open space for the both then they have to be really close, otherwise the stronger of the two can damage the weaker.
i burnt up my amp because i bridged 2 identical svc forsgate subs. i never noticed that one was 4ohms and the other was 2ohm.
