josh_crewdson@y
Ok i don't have time to do the mpfi conversion, so i was wondering if the Dpfi intake manifold will bolt up to the d16y8 head i have sitting around? (water port, etc..) i would think it would since people put z6 manifolds on the b2 head right? I will eventually do the mpfi swap, but i need to replace the head gasket now so why not make it a minime now while it's apart.. I know i need the y8 timing belt and head gasket, i will not use vtec till after the mpfi swap, but everything else just bolts up correct?
