theczechone
Ok, so after two weeks of worry free driving my hatch is at it again. (B16A, p30 ecu)
Yesterday I drove for 300 miles cruising at around 80mph no heavy acceleration or even vtec engage, car ran great the whole way, this morning I drove additional 50 miles stopped and than 20min to work. I was almost at work and i notice the car stumbling while cruising I feel the engine cut out. I press in the clutch and the engine comes to an idle and I can rev it as much as i want to, put it back in gear and accelerate while accelerating the engine cuts off. I'm at work for 8 hours go to leave for home and the same thing is happening. I almost get home while driving with this problem and the car cuts out completely (don't know if relevant but car was on an incline), the car refuses to start after many tries. I get some help to get the car to my driveway only 6 houses up the hill (on flat surface) and try to crank the car after the fourth try spinning the engine the car starts revs fine while in neutral, but if in gear same problem.
the distributor is 2 weeks old
new spark plugs, plug wires 2 months ago
new o2 sensor 4 weeks ago
Ignition timing is set at 15.8 degrees BTDC
Any input is appreciated
