Ok here were i am lost it tell me to move C1 and C2 to B10 and B12 but there a wire in B12. Do i just de pin that one at B12 and let it lay there??? I found a link said some cars have the wire there and its one less thing i have to do.
also i found a link that tells me to use b2 and b11.
Best Method To Do This:
-Pins B10 and B12 are empty meaning there are no wires going into them as a general rule, however some models have a wire at B12 (if you have one that is one there that is one less wire you will need to move).
-Pins B2 and B11 have wires going into them but they are not used for anything (weird, but trust me on this one).
-Take the pin/wire from B2, depin it (this means pop it out of the plug) and pin it (pop it into plug) into B10's empty spot, how you have a wire at B10.
-Take the pin/wire from B11, depin it and clip it into the B12 spot, now you have a wire at B12.
-Cut the orange C1 wire and white C2 wire "in half" (by cut in half I mean cut the wire making sure to leave enough wire so you can strip and solder them to another wire later). Now when dealing with cutting I will refer to the side of the wire coming from the interior harness as the harness side, and I will refer to the side of the wire coming directly from the ECU's plug (direct ECU connection) as the ECU side (the only plug in question for this step is the ones that go into the ECU).
-At the ECU plug, for C1 and C2 solder and heatshrink wires to them and run them into the engine bay (I did this via the A/C grommets). Mark these wires with a piece of tape saying C1 and C2 on it. Because if you are like me you were using black wire which all looks the same so you need to make sure you know which is which.
-Now connect and solder the ECU side of B10 onto the harness side of the orange C1 wire, then do the same for the ECU side of B12 and the harness side of the white C2 wire.
-Cut wires at A3 and A7, solder and heatshrink wires to the plug side of A3 and A7 and run them into the engine bay, make sure you mark them. Now you should have 4 wires running into your engine bay.
