Prelude S, F22B1 swap from F22A1
Superaison
I have a 1994 Honda Prelude S w/Manual Transmission, with a F22A1 I swapped into it back in december from a older accord. The other day the thing took a dump, and in cyl2, the rod let go. I found another engine, an F22B1 out of a 1996 Accord w/Automatic Transmission that has 80k miles on it.
I plan on picking up that engine on thursday. I know I have to swap out my harness, injectors, and alternator, and distributer, to make it work on my OBD1 Prelude.
I plan on using a H23 tranny I have sitting in my garage with a Stage 1 clutch and OEM flywheel. I have a POA ECU sitting around I plan on using.
Can anyone give me their thoughts on this swap? I am not made of money so a H22 or H23 is out of question(I can't even find any haha).
I also have a full h23 sitting in my garage(incase I need anything off it lol, it needs bottom end rebuilt)
im not sure if the h23 trany will bolt up to the f22 engine, u might need a adapter plate
All H and F motors and transmissions are interchangeable. The only exception would be the S2000 motors (F20C and F22C). That's like Honda 101...
