hey guys i just picked up a 91 hatch with a b18a1. this guy that had it blew a head gasket and replaced it. he did a wire tuck also. since then it will not start. it turns over but wont fire. and you cant remove the key untill you remove the negative cable from battery. then you can turn ignition back far enough to remove key. i need ideas. also the main relay acts like it is not working right. thanks
