ob2 si
electron_si
first: i tried searching and couldn't find it
i want the skunk 2 p28 (or similar) ecu with earlier vtec engagement and better fuel and spark curves but i was wondering if this was a smart idea because i would have to convert to obd 1. is this a good idea. if so should i ebay the obd2 to obd1 conversion harness.
obviously im really new to hondas so thanks for the help
converting to obd1 is a smart idea (provided its legal in your state/regioin) for performance.
the skunk2 chip, and all the other INSERT PROGRAM HERE chips however,ares worthless.
90% of the time, earlier vtec will loose you horsepower.
Ecu mods should compliment engine mods. So what have you done to your motor?
the skunk2 chip, and all the other INSERT PROGRAM HERE chips however,ares worthless. 90% of the time, earlier vtec will loose you horsepower.
+1
Never, never, EVER put a chip in that isn't tuned for your vehicle. If you have a stock motor, you need to run a stock ECU program. 'Stock motor' includes I/H/E and other basic boltons. If you have mods done to your motor, such as cams, pistons, F/I, then you need a program that is tuned specifically for your car.
wow! im definetly glad i asked then because all i really have so far is I/H/E and lightweight fly wheel and clutch. ill keep my stock ecu then unless i decide to do internals. thanks for the help
I own a stock B16a5 automatic SiR. What possible mods should I be looking at to increase performance. I was thinking of a chip. I don't plan on doing anything internal yet.
