what is the compression in the cylinder. get a compression chech or do one. idk what good compression for that motor is but at 100,000 miles your good.
go to
Homemadeturbo.com
all info you need. the for sale threads in there can get you most everything for a good price.
Manifold 150
wastegate 100 ebay
bov 75 ebay
pipeing 200 thats figured real high with couplers
turbo 200 used
FMIC 150 i have one if you want it for less.
Oil lines 75 stealthmode 75 shiped ftw
mis 50 t fitings vac hose. zip ties.
total 1000
fuck injectors 219 new. 50 used 440cc should be fine
well $1050.
but again the more you look the lower your price will be.
dosenot include a tune. Xenocron sells chiped ecu and can get you a base map. find some one local who can tune with crome
can you weld. if you can go dumster diveing at a local exaust shop. you can get used stuff cheap.
check out the site i said.
Info SSautoChrome is shit. i have there manifold, cheap cheap cheap and it will crack. everyones dose so dont buy one of those off ebay.
cheap chinese turbos are a no no to. i have one and have not used it. i am going to put it on my new setup and see how long it lasts. try and find a used turbonetics or garett. the chinese are a hit and miss so it might last but it might not.
need help pm me
