Hi,
I just recently put an h22a into my 96 accord. The egine came out of a 1994 Honda Accord SiR. It came complete with engine, tranny, ecu, tcm, engine harness, alt, ps, ac, distributor. This motor has an internal coil. My car had an external coil. I did all the wiring correctly and triple checked to make sure all the colors are matched up perfectly. They were soldered and heat shrunk. The only problem I have now is that the car cranks over and gets air and fuel but no spark at all. I have checked the timing and its good. I am using the distributor that came on the motor. I was thinking the ignitor was bad. Any one with some info would be greatly appreciated. Thanks. Oh the ecu harness was made by rywire and all the wires are connected as well. Thanks
