get_nick said:a turbo kit
dragonsol said:i'm looking for the best mods for a d16z6. its in a 94 del sol
B16DelSol said:Headers, and Intake would be your best bet for quick HP. you could also get a timing belt kit, this helps your exceleration and a new throttle body would add another 10hp.
christopher said:I have the head off now going to clean up and gasket match the ports ,3 angle valve job and dyno it again and see whats gain in hp & TRQ. I am going to put a LS throttle body, cam gears and light weight crank pulley and dyno after each part is added to see the gains or losses o each part I'll try and report my finding.
well, first off, what are you looking spend here? of course start with your basic more common upgrades such as Intake, headers, and exaust. once you've covered that, then you can go with other mods, such as turbo's, superchargers, cams, ecu's and such. but make sure your engine can breath real good before you throw anything big at it, k. good luck bro.
~Ryan
That's actually pretty good. It will give most B16 swaps a run for their money.
wow, not only did you call one of the coolest guys on here a fucking retard, but he's also admin. and he was referring to 133hp to the wheels a good competition with a b16 that has 160 crank hp, so about 130hp to the wheels. i think you're the fucking retard.Your a fucking retard!!! B16's have 160hp STOCK...
Dude GO TURBO!!! I have a D16Z6 Turboed del sol and I love it..trust me go turbo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
