87 Accord Lxi Running Like Crap
i have a 1987 accord lxi 2.0 and it's having some issues.
it starts fine, but the idle is kinda high, and revs up and down when the engine starts to warm up. (idle air bypass maybe?)
when it's in gear and cold, it runs fine, but the idle is a bit high(1100rpm or so) and as it starts to warm up it bogs down when i accelerate from a stop, but it doesn't stall out. if i just keep my foot on the pedal, but don't go WOT, it will eventually get up to speed, but runs like crap. if i go WOT (kick in the passing gear) it accelerates fine, though i try not to do this if i can avoid it.
also in gear, at a stop, the rpms will drop off a bit, down to 700 or so, and will start to idle a bit rough, not missing per say, just a bit rough. it will do that for a couple seconds, then the idle will kick back up to 1000-1100 or so and even out.
once i get up to cruising speed, it runs fine. just seems to bog down on acceleration or under load(going uphill).
the PGM-FI light comes on when the car is at operating temp.
i need a thermostat too, so i'm kinda wondering if maybe the combination of the idle air bypass valve and the thermostat would be the cause of these problems.
i've put a tune-up on it 3 months ago - cap/rotor/plugs/wires/air filter/oil change/filter. has a complete new exhaust from the downpipe on back, including new catalytic converter and high flow muffler.
any info would be greatly appreciated.
