92 prelude to h23a vtec swap
RHS3
Been awhile since I have been here so here we go. A friend of mine has 92 prelude w\ stock h23 and he wants a 96+ h23a vtec swapped in. I'm thinking simple bolt in swap minus a little wiring. The setup he's looking to buy is engine, transmission ecu harness sensors cables mounts and complete intake. Any thoughts, any disagreements, anything I'm overlooking?
Would u happen to no what kind of harness u would need for an h22 swap into an EG hatch i got the complete h22 now and a p13 ecu what else would i need other than the mounts?
i believe that you can use the f22, h22, or h23 which ever you can find or find cheapest. the f22 and h23 there will be some other wiring like for vtec. axles will be something that you need to find. im not sure what the combo is for that application
you always use the stock harness for your car, modify it, and add any needed wires(VTEC, IAB, KNOCK)
