brian11to1
ever since i put my lsvtak together i've had issues with smoking...
well i finally tracked down the problem. turns out it was a line i was using for my catch can that was leaking oil onto the exhuast manifold making me smoke under acceleration, in vtec and only when warmed up.
so, now i've devissed a new better catch can breather system... but need some info/insight on if its good nuff...
basically i will be venting via the valve cover as well as two nipples on the back of the block.
I want to know if i should just freely drain into the oil pan or should i have a valve in the way of the drain?
see diagram.
see diagram.
