Tech Question on wire for my tachometer ??
EvoIX4me
Just trying to get a response to help me wire up my Autometer shift light /w pill module . Also what pill should i use with my 96 spec JDM ITR ? 8,400 8,600 ? 8,800 ?
1st- green goes with tach signal wire which is blue?? is it the light blue or dark blue wire i tap into by the wiring harness by the distributor ?
2nd- black wire is ground.. got that.
3rr- red power source fuse box under dash ?? Where to wire that to ?
on the driver side up by the windshield under the hood beside where the hood bolts up there will be a blue wire with a rubber boot over the end just tap in right there for the signal wire. power source any source will work that comes on with the switch
NIce ! i found that little blue wire with rubber boot your talking about . Maybe i will power it to my ignition fuse :)
