Tech Question on wire for my tachometer ??
Discussion in 'General Tech and Maintenance' started by EvoIX4me, Apr 9, 2007.
  1. EvoIX4me
    EvoIX4me New Member
    Just trying to get a response to help me wire up my Autometer shift light /w pill module . Also what pill should i use with my 96 spec JDM ITR ? 8,400 8,600 ? 8,800 ?
    1st- green goes with tach signal wire which is blue?? is it the light blue or dark blue wire i tap into by the wiring harness by the distributor ?
    2nd- black wire is ground.. got that.
    3rr- red power source fuse box under dash ?? Where to wire that to ?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    on the driver side up by the windshield under the hood beside where the hood bolts up there will be a blue wire with a rubber boot over the end just tap in right there for the signal wire. power source any source will work that comes on with the switch
  3. EvoIX4me
    EvoIX4me New Member
    NIce ! i found that little blue wire with rubber boot your talking about . Maybe i will power it to my ignition fuse :)
