Auto to manual conversion
hondavet
Designed and made this for my 96 civic hatch. Planning to make more of these if anyone is interested. $50.00 primered. You'll also need to get the rubber boot.
Stumbled onto this post by accident. Was looking for info on changing to a MT but this is a pretty cool creation you've got there!
Nice work do you have any thing worked up for the clutch pedal. Might be nice to market a full conversion.
how hard was it converting the tranny? Im in the process now and i need all the help i can get. computer wise what did you do?
Trans was the easy part. Obviously you'll need a manual ecu. You can use one of the auto shift solenoid connectors for the back-up light switch. The trans mount is different also. My mounts came with the type R motor I bought from Hmotors. 8lb Fidanza flywheel works nice too along with a stage 1 Exedy racing clutch. Wiring mods were pretty straightforward, get yourself a wiring diagram, or copy the pages from the factory etm. I have the schematics in pdf format that I think I can email.
