does anyone know if a b20a5 fuel injected head will fit on a b20a3 block? the a3 is carborated. the a5 is an 89 model si, the a3 is an 88 model s. thanks!
The displacement is correct, but I believe that just swapping the head is not going to solve the rest of the problems that it will cause. You need to swap everything.
I mean: Fuel lines, fuel pump, engine harness and ecu. A lot involved.
