b20a5 and b20a3
Discussion in 'Prelude' started by delsol28, Sep 24, 2007.
  1. delsol28
    delsol28 New Member
    North Alabama
    does anyone know if a b20a5 fuel injected head will fit on a b20a3 block? the a3 is carborated. the a5 is an 89 model si, the a3 is an 88 model s. thanks!
  2. 1Funryd
    1Funryd Member
    The displacement is correct, but I believe that just swapping the head is not going to solve the rest of the problems that it will cause. You need to swap everything.
    I mean: Fuel lines, fuel pump, engine harness and ecu. A lot involved.
    Here is a swap from a member on preludepower.com
    Squishypanda's B20A3 to B20a5 swap
    Sean
