Need help tryin to swap ZC into 93 coupe
93civic2dr_bake
New to swapin
I've searched this site and got lots of information......but still need some help with this swap. Went to couple of shops and can't afford to have them swap it.
For one can't find the specs for torque for the bolts and I know I need to do valve lash.....how????
Looking for a OBD 1 ZC dizzy think it is a TU 43......all I know is OBD 1 dizzy.
Check out www.thezcr.com for most of your torque specs and there is also a breakdown on how to adjust the valves on there. I had to replace my dizzy last year and got mine through ebay. hope this helps!
Ok went on there and can't find shit on the Crankshaft bridge torque........found everything else...... very good info thanks!!!
If you cant find it i belive you could use the torque specs for the d16a6 or d16a9 block, i am not 100% sure on this though.
Thanks man I did a little more pokin around and found it. I put the bottom end and the head on. Will post more later on tonight. Will try to put cams on and do valve lash tonight.
Forgot to get cam seals so I have to wait till monday and order them. My package with the rest of the engine should be here tomorrow. Then I can start putin that together.
Would it be a little easyer to leave the intake and exhaust mani off then plant the engine.
When installing the motor i would say definitely leave the intake on and as for the exhaust, its up to you.
I'm stuck I torqued down the head.....the manual says to valve lock nuts should be loosened and adjust screws backed off...wtf are those? Replace rocker arms in orginal positions...does that mean exact places cause....I don't know that....?
Here's a pic from one of my repair manuals...hope this helps!
Thanks that is what I needed got the cams and gears on. Now I'm just tryin to get an OBD 1 dizzy for the DOHC ZC.
Found an ZC pm 7 ecu can I just put that in the car instead of swapin the dizzy and keep the OBD 0 injectors in the engine?
If yall didn't see I have ZC cable tranny, 93 civic coupe interior parts, and subs fs.
https://hondaswap.com/parts-sale-trade-wanted/89-zc-cable-tranny-mic-94762/
